An attempt to process an ATG_I3_INET_ADDR_IND on a received I3 Stub message has failed either due to local resource shortages or receipt because the I3 has indicated that it has lost data. The information is requested from the I3 stub again on a timer.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Warning
An attempt to process an ATG_I3_INET_ADDR_IND has failed due to local resource shortages or indication that the I3 join has lost some information for the request VR = %p1% I3 join index = %p2% Data lost flag value = %p3% Local resource ret code = %p4%
Name | Type |
p1 | uInt32 |
p2 | sInt32 |
p3 | uInt8 |
p4 | uInt8 |
